Showcase
We'll like to customize the Showcase viewing area. What are our options?
Hi there,
If you are using a hosted JW Showcase, meaning one that you configure through your Dashboard, you would be limited to the options available in the Dashboard. With that being said, you are able to add custom CSS on the “Advanced” tab by selecting the option for a custom header. You also have several options for design customization on the “Design” tab.
If you are using the open-source, self-hosted JW Showcase, then you can customize it any way you want but this would require custom development is not something we would be able to provide assistance with.
Thank you.
