Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Where is my license running?
Hello,
where can I see on what IP oder URLs my jwplayer license is running?
1 Community Answers
Donni
JW Player Support Agent
0 rated :
You can get this information by applying mediaIDs to your embeds and then checking the OVERVIEW section of your analytics. One thing to note is that according to the terms of service you can only use the player on one domain. If you are using the player on multiple domains you will need to upgrade your account.
