downgrade jwplayer 7
I upgraded my jwplayer 8 but I want to downgrade the jwplayer7.
Unfortunately, once you upgrade your player to JW Player version 8, you cannot downgrade back to JW Player version 7.
Hello,
i need to downgrade to JW 7. JW 8 live streaming playback is not smooth at all.
The best way to achieve your desired result is to implement a new JW 7 player. You cannot downgrade a JW 8 player to a JW 7 player.
what file is changed when I upgrade to jw8?
My file is not open after upgrade.
Can you clarify what file you are referring to? Your video file?
