Bug Report WITH JWPLAYER 7 and JWPLAYER 8 Fullscreen toggle
There is a big bug in both JWPLAYER 7 and JWPLAYER 8. I wonder why nobody reported it yet, as it is quite serious.
Problem discovered: on mobile (preferably android, others I haven't tested), or in chrome you can test this bug in mobile view inspector mode. Make the screen as long as you can, and minimize the inspection tool.
When you go into fullscreen and then use the toggle fullscreen button to go back, an extra click is triggered. Most probably it has something to do with the tap function on mobile.
Here you can see the problem on android phone or chrome mobile inspector tool:
https://output.jsbin.com/yedewalepi/1/
When you toggle from fullsceen an X is drawn to prove the extra click/touch etc.
I tested and both JWPLAYER 7 and JWPLAYER 8 has this bug. It can and are causing a lot of trouble if there is something there under the video links etc.
