Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
connection timeout
I am getting an Error "Error Loading stream: could not connect to server" on web page While streaming through Android Application.
4 Community Answers
George
JW Player Support Agent
0 rated :
For me to reproduce this issue reliably I will need this information about your application:
Device’s Android Version:
JW Player SDK for Android version number:
Device make and model where you are experiencing this issue:
Provide step by step instructions on how to reproduce your issue:
JW Player Demo Application Source Code that is also experiencing the issue:
As the last field suggests, please replicate this issue using the JW Player Demo Application and send us a link to a zipped version of the entire Android Studio Project for testing which can be found here:
https://github.com/jwplayer/jwplayer-sdk-android-demo
Salvatore Monaco
User
0 rated :
"Setup Timeout Error: Setup took longer than 30 seconds to complete." is that I read to select a video live streaming in Elevensports.it. I have this problem in any pc desktop with win 8 and win 10 as SO, and any browser (Edge, chrome and Firefox). I test every set up Browsers, Firewall and Antivirus, whitout success. Only access with smartphone Android I don't have any problem.
Thank you
Salvatore Monaco
User
0 rated :
Asus Zenfone 2, and hawey p9 lite, there are ok. the problem is only for pc desktop window SO
George
0 rated :
Are you a viewer or the developer of Elevensports.it?
