Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
jw player
I need jw player so I can install direct to a website but there is no way of downloading it I need it to replace flash player as the main stream setup and config for the site
we keep getting from flash not supported
need jw direct download its only for this site I am altering
1 Community Answers
Donni
JW Player Support Agent
0 rated :
You will need to use a cloud-hosted player if you are on a free account.
