JW player Integration for appleTv os project in swift3
how to integrate JW player for Apple TV OS in swift3 ??
I assume you are referring to our Apple TV product- https://github.com/jwplayer/jw-showcase-appletv. If I am correct, you can upgrade the project to Swift 3 by either agreeing to upgrade the Swift version when you first open the Xcode project. Secondarily, once the project is open go to the top bar → Edit → Convert → To current Swift syntax.
