Seek Does not Work
Hello.
Jwplayer seek() does not work in my website.
Live site & script : tvrohani.com
Can you please help me?
Thank you.
Hello.
Thank you.
Okay so it works now. It's weird. It seems sometimes it works, sometimes it does not.
Why sometimes it does not work (the video played from 00:00:00)
You are playing back an MP4 so it might not have downloaded the file to the point you want to seek to.
Hello Donni.
So should i use other file format? Maybe MKV or something else?
Can you suggest what file format is the best to use seek method?
Thank you.
I would recommend you purchase the Platinum Subscription which will give you adaptive streaming and let our platform automatically convert your content to HLS which seeks better.
