Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Adserver vs. Player
What's the role of a an adserver and a player when defining e.g. skippable ad, skippable after x seconds, countdown, ad labeling. Is this Information coming from the adserver or is it part of the player? Are different creatives for the different uses cases necessary? Thanky
1 Community Answers
Heidi
JW Player Support Agent
0 rated :
Hello,
You will want to get started with our documentation here to understand the various ways that ads are delivered, and what JW supports:
https://support.jwplayer.com/customer/portal/articles/1431638
With regards to what you list above:
Depending on whether you are using VAST, Googima, or VPAID ad tags:
VAST: You are able to configure skipping via the player
Googima: Skipping must be configured in the DFP dashboard, skippable Googima ads do not play on mobile
VPAID: Skippable will be configured in the ad creative, we suggest using Javascript creative for the best cross-browser, cross-device support
Our ad tag tester here:
https://developer.jwplayer.com/tools/ad-tester/
includes some sample ad tags that demonstrate the behavior of a few different ad types we support.
Hope this helps.
Heidi
