Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
JWPlayer 7 iOS 10 iFrame audio muted
Hi,
When attempting to stream audio to iOS 10 devices the playback on the page is using a iFrame of the player. The audio is muted by default though. When viewing the iFrame source playback is typical and not muted. IS this something solely iOS is doing as a security measure and is there anyway to get the audio to playback unmuted when supplied through an iFrame?
1 Community Answers
Donni
JW Player Support Agent
0 rated :
This is most likely because you are autoplaying content – can you provide a test page if you are not setting autoplay to true?
