RADIO STREAMING
HOW CAN I USE JW PLAYER TO STREAM LIVE RADIO BROADCAST ON MY WORDPRESS SITE? CAN I USE WINAMP OR WHAT IS THE BEST WAY TO DO THIS WITH JW?
You’ll probably want to use our Wordpress plugin to embed the player and streaming software that creates HLS streams since that is the most compatible streaming format around nowadays and works great with our player.
Thanks Donni, but how can i get this done apart from installing the plugin? Where can i get help to this.?
You could try something like https://www.upwork.com/ to hire someone to help you with this.
Where do i get streaming software? I want to it myself i just need some guide to what and where to get it. I already have JW account.
There are many applications out there, I’m afraid we don’t have a specific HLS encoder we recommend.
Thank you
Can please give me few TLS names that you know if you don't mind
Sorry I’m not sure what you mean, can you elaborate?
I want to know what software i can use to stream with JW. You mentioned TLS encoder which i don't know about. I just want to know the ones that work with JW so that i can make my choice.
I think you mean HLS encoder – but we don’t have a specific one we recommend I would search for “http live streaming software” and see which one fits your technical abilities and workflow.
