How to disable audio button from default Jwplayer 2.7.3
Hi,
In Jwplayer 2.7.3+19 android sdk
I want to disable audio button from player , as the player started controls are not visible on player instead showed me one audio button until and unless i press that audio button i am unable to see the other controls, I tried with .mute(false) doesn't work for me . Any other way to do that work
Thanks
Ganesh
