Streaming embed code with captions
I am trying to use the streaming option, which appears to require the single line embed code, but would like to add captions on the fly. I have 2500+ videos, so adding them all via the dashboard would be very time consuming, and there are occasionally bulk edits that would be tedious to do if I then have to reupload through the dashboard again. I know there is the long form embed option which allows for adding captions, but from what I've read that does not work with HLS, etc streaming options. So basically I'm trying to figure out how to do both, use the streaming option and add captions on-the-fly in the embed code. Is this possible?
