Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
JW6 style listbar?
Is the JW6 style listbar expected to return sometime in JW7? Many would like to be a good addition to the visual playlist. Unfortunately, there is no good plugin. The listy plugin is not a perfect solution :(
7 Community Answers
Daniel Berger
JW Player Support Agent
0 rated :
You can achieve that layout with custom CSS and JavaScript. Here is a code example: http://qa.jwplayer.com/~todd/jw7-playlist-custom-listbar.html
Please let me know if that was the behavior you were seeking.
hevesi2010 N/A
User
0 rated :
Thanks for the reply! I would not like this as your example. Such (or very similar) solution would be really good: http://www.exonmusic.hu/videok
Here I would like to replace old v6.12 for latest v7.x version. Music (upper left corner) and video player.
Daniel Berger
0 rated :
You are welcome. You can achieve that custom setup by implementing a playlist of videos. Here is a document to assist you: https://support.jwplayer.com/customer/portal/articles/1481963#fndtn-code
You can upgrade to JW 7 by signing up here for a free account: https://www.jwplayer.com/pricing/
hevesi2010 N/A
User
0 rated :
Hi Daniel,
Unfortunately I can not do what I need to do. So I have to stay in the JW Player 6.
Daniel Berger
0 rated :
No problem. Please let me know if you have any other questions.
Best of luck.
h...
User
0 rated :
Maybe the listbar feature is back at sometime and i can again easily put it the vertical scrollable playlist below the player.
OK, I know ... I just dream :(
Daniel Berger
0 rated :
You are always welcome to create your own custom page setup with JavaScript.
