Airplay casts only audio using JW Player v.7
After upgrading to v.7, using Airplay , iOS devices cast only audio to Apple TV. Is there a fix for this condition?
Can you provide a test page with your content and player so I can test it with my demo devices?
Here's the web link: http://mywpc.org/livebroadcast.aspx?parentnavigationid=26208
Sorry Donni, I should have read the description of a test page before posting the URL of the JW portal. Faith Network is the web page manager, and would have the info for the test page. Just let me know if you have the same problem in casting video using this web site and I'll go from there.
Hi Barry,
Thanks for the demo page, now I understand! The behavior you are describing is the iPhone’s built-in ability to cast audio via airplay. To enable casting video with our player make sure to add cast: { },
to your player setup. Read this article for more details.
Let me know if that helps,
Donni
This fixed the problem. Thanks so much for your help.
