autostart JWplayer on WIX site
How to automatically start the drive on a wix site (html code)?
thank you
thank you
If you are using the cloud-hosted player, you can do this within the Manage section of your dashboard. Click on your desired player and you will be re-directed to it’s setup properties page. In this page you can enable auto-start and configure other options for your player.
If you are self-hosting the player, set autostart: "true"
Check out our Embedding with JW Player article for more information on the different embedding options.
