Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Android JwplayerVIew not fitting horizontally in android.
Jwplayer view is not fitting completely horizontally while playing. There are black space on both side of the player in android.
how to remove those, as i need it to completely fill the space.
3 Community Answers
George
JW Player Support Agent
0 rated :
For me to reproduce this issue reliably I will need this information about your application:
Android API Build level (16,17… 22):
JW Player SDK for Android version number:
Device make and model where you are experiencing this issue:
Provide step by step instructions on how to reproduce your issue:
JW Player Demo Application Source Code that is also experiencing the issue:
As the last field suggests, please replicate this issue using the JW Player Demo Application and send us a link to a zipped version of the entire Android Studio Project for testing which can be found here:
https://github.com/jwplayer/jwplayer-sdk-android-demo
The black space could be the layout, it could be your video, it could be aspect-ratio, a demo application would help me understand the issue better.
r...
User
0 rated :
I am getting issue when i use jwplayerView, With player fragment it is working fine and that too with same url.
config i am using it to
minSdkVersion 17
targetSdkVersion 24
JW Player SDK for Android version number: jwplayer-android-2.7.0+15
Devices i am using : One Plus 2, Nexus 5 from LG, Moto g2
George
0 rated :
I’ll need the Demo Application Source Code that is also experiencing the issue:
Please replicate this issue using the JW Player Demo Application and send us a link to a zipped version of the entire Android Studio Project for testing which can be found here:
