Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
AES encryption and JW - Showcase
With the enterprise package at JW player, you can encode HLS with 128 AES. Jw-Player can play AES protected streams. However, Jw-Shocase as stated on 3/2/17 on the GitHub page says its not supported. Any support or roadmap to be able to playback using Jw-showcase? If not, can a web developer add it and how hard of a change is that?
Doug
1 Community Answers
Alex
JW Player Support Agent
0 rated :
Hi Doug,
I would recommend raising this question directly with the developers behind the project by adding an Issue to the project’s GitHub Repo.
https://github.com/jwplayer/jw-showcase/issues
Thank you.
