Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Not able to change volume and bitrate in IE9 & IE10
I am using Jwplayer version 7.8.7 (Premium version).
While playing video , in IE9 & IE10 When I hover over volume indicator to bring up the volume slider at that time if I try to change volume , volume slider disappears.
Due to that I am not able to change volume.
Same issue exists for bitrate toggling. I am also not able to change bitrate. When bitrate switching option brings up and I try to select bitrate immediately bitrate options disappears.
Issue exists only for IE9 & IE10
1 Community Answers
Alex
JW Player Support Agent
0 rated :
Hi there,
I am unable to reproduce any strange behavior with the HD or volume buttons when viewing a HLS stream on our Stream Tester in both IE 9 and 10 in Windows 7. The HLS stream I tested with is:
https:///playertest.longtailvideo.com/adaptive/bbbfull/bbbfull.m3u8
If you are still experiencing this behavior, can you please send me a URL to a reproduction page?
Thank you.
