Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Could not build latest JWPlayer
Hi,
I could not build the player locally, I am getting this error :
node_modules\jwplayer-flex-sdk\lib\flex_sdk\bin\mxmlc.bat ENOENT
After running grunt build.
Not sure if this related, running npm install:
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules\chokidar\node_modules\fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.0.17: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
Thanks
1 Community Answers
Randy
JW Player Support Agent
0 rated :
Hello,
Are you trying to customize the player code for hosting locally? If so, this is not a supported measure and negates the ToS: https://www.jwplayer.com/tos/. You might consider looking at our locally hosted player as this would allow local hosing of the JW Player code.
Randy
