Multiple Formats Turn to Two on Mobile
Looking at your guide on multiple formats;
If there are 3 or more file qualities and the viewer is on a mobile device, JW Player will still toggle only between the first 2 qualities. This to keep the interface easy to use with Touch controls.
Isn't this backwards? Since the higher quality formats are listed first (so they are on top, like YouTube and every other player), would this mean that mobile would only play that top two resolutions instead of the bottom 2 resolutions (it should be doing the bottom 2).
Is it possible to get mobile to use the lower resolutions and not the top resolutions? It looks odd when you mouse over HD and see the lowest resolution on top.
Cheers
Ryan
