Akamai Playout Problems - JW 7.8.6
We've been using the following plugin for the past couple of years with out issue for both Wowza & Akamai playout:
"flashplayer": "//ssl.p.jwpcdn.com/player/v/7.8.6/jwplayer.flash.swf"
However, we are now experiencing the dreaded spinning wheel from Akamai Edge streams (Wowza is still good Flash or HTML5). Strangely enough, over the period of several minutes, the stream may actually show up.
Akamai is stating that we should be using their flash plugin: http://players.edgesuite.net/flash/plugins/jw/v3.10/AkamaiAdvancedJWStreamProvider.swf
However, I'm not seeing the logic since HTML5 is primary and the fact that we're not seeing these issues from Wowza.
Here are some links (currently no audio on this stream).
Here's our 24/7 live-steam embed link: http://media.liberty.edu/apps/live/jw/ch71
JW Platform players (same player as above):
Test player Akamai link: http://content.jwplatform.com/previews/JBjIWfuI-FYOzB2F9
Test player Wowza link: http://content.jwplatform.com/previews/9mFYoU2O-FYOzB2F9
We've tried this on different PC's browsers with and without flash. Any of you running into this and any ideas what might be causing this problem?
