Position of Closed Captions
I am working with an HLS stream that has closed captions embedded into the stream. Various player versions have treated the captions differently. In 7.2.4 when using HTML5 I was able to view and style the captions in the HTML using CSS. When I upgraded to 7.8.2 I am no longer able to access/view the captions in the code.
I have been requested to make the captions display at the bottom of the screen with the text centered. What is the correct way to make that adjustment?
