In 7.8 the HD menu does not display labels for quality levels
I'm testing using JW Player 7.8.0-rc1 in advance of Chrome 55 and I have discovered an issue with the quality settings.
In 7.8 it shows the diffrent qualities as Resolution (Bandwidth), i.e. 720p (1888kbps). In 7.7.4 it displays the labels I have assigned to the qualities. In 7.8 these are ignored.
Here is a test page with 7.8.0-rc1 where the issue can be seen:
http://meghananderic.com/jwplayer/78/
For comparison, here is the same playlist and setting, but using 7.7.4:
http://meghananderic.com/jwplayer/77/
How can this be fixed?
