Problems with VAST advertising
Hi,
From previous versions I have problems with advertising in VAST format, most of the time does not reproduce advertising, now I can assume that it reproduces but the image is not seen, only the audio is heard, this I suppose in the preroll of the original demo of jwplayer.
I think that in version 7 of the player already would be solved, but I see that it continues the same.
Could you please check it?
Demo URLs
http://img.lagaceta.com.ar/externos/JW-Player/demo-7.7.4-vast2-eplanning.htm
http://img.lagaceta.com.ar/externos/JW-Player/demo-7.7.4-vast2-original-demo-xml.htm
http://img.lagaceta.com.ar/externos/JW-Player/demo-7.7.4-vast3-eplanning.htm
VASTs:
Version 2
- http://ads.us.e-planning.net/eb/4/5b67/Deporte/Video_Player_Brightcove?o=v&ma=1&vv=3
- http://s3.amazonaws.com/demo.jwplayer.com/player-demos/assets/preroll.xml (Demo original)
Version 3
Thank you.
Regards!
