Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Adaptive Bitrate Caching Issue
I am using Jwplayer 7.7.4 and i have implemented adaptive bitrate through hlshtml:true
I face one problem since long.
Please check below use case
Use case:
I have 2 video on same page, both jwplayer instance's Id is different
Now I am playing video 1
In video 1 "Auto" quality is selected by default which is true.
Now I am changing this quality to "720p"
After that when I am playing second video.here for second video quality should be "Auto" selected, but instead of "Auto" it "720p" quality selected by default.
After that again I play video 1 , here also instead of "Auto" "720p" quality is selected.
Now when i clear cache then again "Auto" selected by default.
May I know the reason why this happens?
Is this cache problem?
Also please provide me a solution to resolve this issue.
I want to select "Auto" by default each time When I play other video.
1 Community Answers
Alex
JW Player Support Agent
0 rated :
Hi Jagir,
It looks like you already emailed the Support Team about this issue and my colleague, Randy, responded to you 45 minutes ago. I would ask that you continue the conversation with him via email.
Thank you.
