Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Custom Parameters for Player Playlist
Customizing a player playlist for audio only but cannot seem to find any examples of "Custom Parameters" for use in the Playlist Dashboard. Would like to make changes to the layout of the default player. Anyone have example of how to use the Custom Parameters - anything would be helpful. Thanks in Advance! KG
1 Community Answers
Randy
JW Player Support Agent
0 rated :
Hello,
I am not sure of the request here as it seems you might be asking for two seperate features. At the moment, we do offer custom parameters for playlists out of the dashboard. You can set this up on the stream level via the “Manual Playlist Detail” tab. You can also customize the look and feel of the player via the “Player Builder” which you can locate in the dashboard as well: http://account.jwplayer.com/
Randy
