DVR Seeking in Microsoft Edge - HTML5
When I disable Flash in Microsoft Edge, its not possible to seek backwards, because the timeline is hidden.
Im using a HLS stream from Wowza - http://wowcasserver/live/stream/playlist.m3u8?DVR
Any tips ?
Any tips ?
Hello Kristian,
There seems to be a bug filed for inconsistencies of DVR on Edge. However you could try changing the minDvrWindow to a lower number and see if that helps.
https://support.jwplayer.com/customer/en/portal/articles/1430265-dvr-live-streaming
How can I change the minDvrWindow when i'm not using the playlist object ?
You’ll have to use the playlist object.
