Upgraded from JWPlayer 6 to JWPlayer 7, smil is throwing a manifest not found or invalid error
Hi,
I just finally upgraded from JWPlayer 6 to JWPlayer 7. I was wondering about smil.
Here is my setup:
jwplayer(content_data['player_id']).setup({
playlist: [{
image: "https://xxxx.cloudfront.net/video_thumbnails/"+content_data['video_id']+".jpg",
sources: [
{ file: "/videos/"+content_data['video_id']+"/getsmil.smil" },
{ file: "https://xxxx.cloudfront.net/"+content_data['video_filename'] }
primary: "html5",
flashplayer: 'https://s3.amazonaws.com/jwplayer/jwplayer.flash.swf',
width: '100%',
height: '100%',
aspectratio: '16:9',
skin: "seven",
screencolor: 'FFFFFF',
wmode : 'transparent'
All the videos produce the same error: Error loading stream: Manifest not found or invalid
If I remove the smil file it works fine. Is this something with JWPlayer 7? Is my setup deprecated? This worked fine with version 6. Any tips is appreciated!
