Missing playlist prev and next
We just updated to the version 7.7.0 and the old control elements are not positioned in the left controlbar anymore?
Further, the prev button is missing. How can we force the old dom structure?
Thanks you
Thanks you
There has been a change in player behavior for playlists. Check out the release notes for 7.7 here. You would need to use an older version of the player if you want to use the old style.
