Adding quality toggle in JW Player from Dashboard !!
Hello,
I'm using JW Player and uploading my live stream to it so I can get the player from the dashboard. I would like to ask if there is a way I can add quality toggle into my player so the viewer can choose the quality that supports his speed. Like I want to add 4 qualities into the player, or this depends on the software which i am using to do the stream if it supports to add more than bitrate ?
I hope you guys got my idea ...
Thanks
