Play/Pause buttons without controls on player 7
Hello,
For an e-learning I like to display only the play and pause buttons. So the users can only play or pause and cannot go through the video using the controls bar.
I found this article, where Ler_Sam found a solution himself. Unfortunately he does not describe how he managed to do this completely:
https://support.jwplayer.com/customer/portal/questions/14364078-jw-7-playe-pause-options
Is there already an easy way to do this?
By the way, Vimeo already has this function to only show play and pause button.
Thanks in advance!
