Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Reg: JW Player iFrame loader - Removal of Border
Hi Team,
One of our client is interested in this JWPlayer approach and would like to have the border removed around the auto Generated Video snapshot when opening the video that need to be played using JWPlayer on the iFrame POP UP.
is there any workaround or fix available for the same so that we can take this up in to our projects for use.
Regards,
Sridhar.
1 Community Answers
Alex
JW Player Support Agent
1 rated :
Hi Sridhar,
Could you possibly elaborate on your issue? The poster image that gets generated for each video that is uploaded is taken right from the video stream so as long as there are no visible borders in the video itself, the poster image should not contain any either.
Thank you.
