JW Player on Iphone and Android
Currently, I'm using JW Player 6.11.4923 (Pro edition).
Has 2 js files jwplayer.js and jwplayer.html5.js
Using to stream the audio file from 7digital
It works good with website but on Iphone and Android can not play:
1. on Iphone: can not play the first one => the second one will show quick time player
2. Android can not play the first one => the second one play good
So, I wonder that does jw player 6 support play inline on IPhone now? Or have any trick to setup that?
Thanks
