Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
jwplayer interrupting the creatives from rendering
Though, now I don’t see any console error message when the player loads,
the issue still seems to be with some code implemented on the player/page
that is interrupting the creatives from rendering on the site.
http://pubads.g.doubleclick.net/gampad/preview_cookie?gct=mvlzs1x30RIY1cPgugUw1d-VwgWIAYCAgKCzyMHkwgE&op=set&redirect=http://player.libertatea.ro/ringiervideo/player_v25.php?width=100%25&stream=/uploads/tx_lsuvideo/UNDE_SA_FUGIM_DE_ACASA_080616.mp4&image=http://static4.libertatea.ro/wp-content/uploads/2016/06/unde-fugim-1-1024x576.jpg&title=Unde%20s%C4%83%20fugim%20de-acas%C4%83,%20miercuri,%208%20iunie!&autostart=1&mute=1&mediaid=9qLGu73z&&redirect_hash=AJlzBa3n3oexiPdk5oiYoC7fk7L1cWuQ3g&lineItemId=73691485&creativeId=97457495125
1 Community Answers
Todd
JW Player Support Agent
0 rated :
The general rule for Googima IMA ad tags in our player is this:
If your tag works correctly in Google’s ad tester at https://developers.google.com/interactive-media-ads/docs/sdks/html5/vastinspector ,
then it should also work in our Ads Tester at http://demo.jwplayer.com/ad-tester/ when you set the ad client to ‘googima’
Is this a Google ad tag? I just tested it in Google’s ad tester and it did not play an ad for me. Are you seeing the same thing on your side?
Here’s a known-good sample Google ad tag you can use to test your player configuration:
http://pubads.g.doubleclick.net/gampad/ads?sz=640×360&iu=/6062/iab_vast_samples/skippable&ciu_szs=300×250,728×90&impl=s&gdfp_req=1&env=vp&output=xml_vast2&unviewed_position_start=1&url=[referrer_url]&correlator=[timestamp]
