JWPlayer Playlists Auto Advance with HWD Mediashare
I am using HWD Mediashare which has a JWPlayer plugin, and have added a playlist within HWD Mediashare, but the playlist does not advance to the next video after the first one has completed ... I am using version 6 of the plugin, and the media player configuration is set to AutoPlay in the HWD configuration ... When I first created the playlist, the autoadvance to the next video, etc., seemed to work, but now it does not and I can't get it to do it again ... If anyone can help with this I would really appreciate it ... even if I have to modify the player code if you can tell me which lines to add/edit to make the autoadvance work.
Thanks
