JWPlayer iOS SDK and React Native
Has anyone experience with using the iOS SDK with React Native? Will it even work together?
Hi,
Reach Native is not currently supported in our SDKs.
Best,
Daniel
I am using the iOS SDK with React Native. It works great! The only issues I'm having is that the iOS SDK does not seem to be as complete as the Javascript SDK. Just to give you some guidance, you will need to create a RCTViewManager to contain the player view and expose the properties you need (file, image, title, controlsEnabled, ...etc) with `RCT_EXPORT_VIEW_PROPERTY`.
Hi Chase,
Thank you for the question. Unfortunately, React Native is not something we support. Please let me know if you have any other questions.
Best,
Daniel
