STREAM RTMP
Hello,
I m trying to display a live stream into my web site (client-serveur). my web site try to connect to the server that generate the stream.
I m using the version 6.12 of JWPlayer, html language, and javascript to embed the jwplayer. I also using the free version of JWPlayer.
I m getting an error of loading stream and could not connect to server.
So, I want to know what could cause this error?
1. is that the Adobe flash player who causes this problem?
2. is that a specific version of adobe that can match with the 6.12 version of JWPlayer?
3. is that a problem coming from the client or the server?
4. is that because I m using a free version of JWPlayer?
my code is typically the same as the JWPlayer's documentation!
Thanks for your help.
