Compiling iframe embed codes - LOTS of them
I'm going to be posting close to 800 videos on a teachable.com type site, porting them over from an existing site.
On the existing site, I'm using a JW6 embed code that contains a dual-version embed code (using rtmp & flash as the primary, and fallback http for the mobile/html5). The only other variable that I really need to use in this embed code is the poster image, and I would like it to be 16:9, at 100%
The site I am porting all my videos over to does NOT accept javascript embeds, and only takes iframe embeds.
I could do all this through the JW7 Publish mode interface, but doing this for 800+ videos will take some time.
I wonder, is there some way to create iframe embed codes (using fallback embed codes)?
Thanks,
Jason
