Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Errors getting player to work.
I am having several problems getting the embedded JW player to work.
When I set "primary":"html5" (or leave it as a default) the player works in every browser except IE/Edge
in IE/Edge the message "This text will be replaced with a player." is displayed.
When i set "primary":"flash"
- It works in FIrefox
- In chrome it loads for a moment then says flash plugin failed to load
- In IE/Edge it says "This text will be replaced with a player".
The filetype is mp4
This is my code
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<script src="jwplayer/jwplayer.js"></script>
<script>jwplayer.key="NDoNxIXotd5wGBwjdgAuzLKrr4Wpt3jhOQgPgA==";</script>
</head>
<body>
<div id="myDiv">This text will be replaced with a player.</div>
<script>
jwplayer("myDiv").setup({
"file": "videos/WEB_INTRO_1.mp4",
"image": "images/P1090566.JPG",
"height": 360,
"width": 640,
"primary":"flash"
jwplayer().on('ready', function(e) {
jwplayer("myDiv").play();
</script>
</body>
19 Community Answers
Todd
JW Player Support Agent
0 rated :
That code looks correct. Can you post a link to your reproduction page?
Does your MP4 play directly when you enter the video URL directly in each browser’s address bar?
Johan
User
0 rated :
Hi,
We have same problems but ut happens only for some ie, older jw player works perfect.
Todd
0 rated :
@Johan, do you have have a link to a reproduction page? Please see http://support.jwplayer.com/customer/en/portal/articles/2186238-troubleshooting-creating-a-reproduction-page for the details we need to see. What versions of IE are causing problems for you?
s...
User
0 rated :
Sorry I dont have it hosted anywhere yet
in IE the console is showing
Unable to get property 'jwplayer.volume' of undefined or null reference
Todd
0 rated :
Understood. We will try to reproduce this on our side. Which version of IE are you using? Which version of Windows?
s...
User
0 rated :
I am using IE 11
s...
User
0 rated :
Incase it helps
i am on windows 10
Donni
0 rated :
I made a test page that has an mp4 and is able to play in IE11 on Windows 10. Here is a screen shot. Let me know if you are still getting that error.
s...
User
0 rated :
I cannot connect to the test page
Donni
0 rated :
Are you able to see the screen shot I attached? If so, are you on a managed network or computer that is possibly blocking access to the player?
s...
User
0 rated :
I on a home network (not managed)
the error is
ERR_CONNECTION_TIMED_OUT
i have the same problem if i try to view the screenshot
i tried turning my anti virus off as well
Donni
0 rated :
At this point I think there’s an issue outside of our control. Are you able to use another network or another machine?
samcoppock
User
0 rated :
I have attempted to access the video and screenshot from a different machine on a different network (with a different OS)
I still get the same timeout errors
Donni
0 rated :
Where are you located?
samcoppock
User
0 rated :
I am located in the UK
Donni
0 rated :
Are you getting that same error when you visit our homepage?
samcoppock
User
0 rated :
no
samcoppock
User
0 rated :
Could it help if i switched to JW player 6
if yes can this still be obtained from the site
Donni
0 rated :
You should have access to the free version in you JW Dashboard.
