I am trying to use chrome cast on my app with jwplayer. The issue is when i select my cast and try to send the video to the chrome cast. my app force closes and the an error with the code 2100 is shown. i tried to google this but i could not find anything related to it. Can you please help me out with this. I'll be really thankful.
Could you give me a little more background on this issue? You mentioned you are having a problem in an app. Is this app an iOS or Android app? Are you using the JW Player SDK?
Yes we are using the JW Player Sdk. We are creating an Android App. Please find the below log. This error comes when the chorme cast button is clicked on the action bar.
==================================== Log Starts here ====================================
03-17 12:30:57.189 10811-10811/com.graymatrix.did E/AndroidRuntime﹕ FATAL EXCEPTION: main Process: com.graymatrix.did, PID: 10811 java.lang.NoSuchMethodError: No virtual method getMediaStatus()Lcom/google/android/gms/cast/MediaStatus; in class Lcom/google/android/libraries/cast/companionlibrary/cast/VideoCastManager; or its super classes (declaration of 'com.google.android.libraries.cast.companionlibrary.cast.VideoCastManager' appears in /data/app/com.graymatrix.did-1/base.apk) at com.longtailvideo.jwplayer.cast.a.onRemoteMediaPlayerStatusUpdated(SourceFile:19615) at com.longtailvideo.jwplayer.cast.b.onRemoteMediaPlayerStatusUpdated(SourceFile:157) at com.google.android.libraries.cast.companionlibrary.cast.VideoCastManager.onRemoteMediaPlayerStatusUpdated(VideoCastManager.java:1505) at com.google.android.libraries.cast.companionlibrary.cast.VideoCastManager.access$200(VideoCastManager.java:134) at com.google.android.libraries.cast.companionlibrary.cast.VideoCastManager$9.onStatusUpdated(VideoCastManager.java:1263) at com.google.android.gms.cast.RemoteMediaPlayer.onStatusUpdated(Unknown Source) at com.google.android.gms.cast.RemoteMediaPlayer.zza(Unknown Source) at com.google.android.gms.cast.RemoteMediaPlayer$1.onStatusUpdated(Unknown Source) at com.google.android.gms.cast.internal.zzm.zza(Unknown Source) at com.google.android.gms.cast.internal.zzm.zzcf(Unknown Source) at com.google.android.gms.cast.RemoteMediaPlayer.onMessageReceived(Unknown Source) at com.google.android.gms.cast.internal.zze$zzb$4.run(Unknown Source) at android.os.Handler.handleCallback(Handler.java:739) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:148) at android.app.ActivityThread.main(ActivityThread.java:5417) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:726) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616) 03-17 12:30:58.261 10811-10891/com.graymatrix.did E/GAv4﹕ Successfully bound to service but never got onServiceConnected callback
==================================== Log ends Here ====================================
I Thank you in advance for any kind of help.
