Wordpress radio streaming question
hi i install the plugin in wordpress to transmit my radio online, my data http://184.172.26.212:11712/, which is the shortcode? use all and does not work
You need to provide the player a link to a compatible streaming protocal in order to play. You may want to use the JW Dashboard to add the stream as an external URL and call it via the plugin.
