Installation JW Player Worpress. 7.4.2
Hi Community,
I am having problems getting JW Player running in my Wordpess Setup. Im using developing the site locally with MAMP using a Multisite setup.
I did install and activate the plugin and uploade the JW Player 7 to my root directory. In the JW Player settings I inserted the path to where the jwpalyer.js file is located, also I inserted the corresponding downloadlink form the site. When saving there is no kind of confirmation or information the combination of path and software key works or is correct. The jw player does not show up when creating a post or when trying to insert the video in a page section.
Please help, I am happy to send screenshots for illustration.
Best regards,
Max Bayer
