Interface language
Hi,
How could I change the language of the interface. For exemple, how could I set the "MY PLAYLIST" title in french ? For instance "LISTE DE LECTURE".
Thanks
M.
Hi,
Thanks
M.
Hi, there.
Are you referring to text that is actually inside of the player? For example, if you hover over the playlist button in the control bar, the top of the visual playlist shows the word “PLAYLIST”? Please let me know.
Thank you.
