Quality switcher doesn't work well in Edge with HLS stream
Hi,
we have a problem in Microsoft Edge, where could by played HLS streams in HTML5 video. We are using adaptive HLS stream as primary source and if config option primary is set to html5, labels in quality switcher are broken (API return only one quality "0").
Try example at https://support.jwplayer.com/customer/portal/articles/1430240-hls-adaptive-streaming and change primary config option to html5
We don't want to set flash as primary, because we are using MPEG-DASH streams in other browsers.
We are using JW Player 7.2.4 and Windows 10.
Thanks for help/fix!
