Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
VMAP - Retrieving current VAST being called
When the player is using VMAP as an input of multiple ads? Is there a way to capture the event and get the current vast tag out from the VMAP XML file. Example if VMAP contains 3 ads AD1 -> VASTTAG1, AD2-> VASTTAG2, AD3 -VASTTAG3, when these ads are being played by the player, can I retrieve the value of the VASTTAG in the javascript API? I want to be able to capture separate events for separate ADS. AD1 fires event 1, AD2 fires event 2, AD3 fires event3. Please guide
1 Community Answers
George
JW Player Support Agent
0 rated :
Hello Somil,
This is George, I had replied to one of your emails, but never heard back, perhaps the email didn’t come through. This was before our linkedIn communication.
If you go to our API docs:
https://support.jwplayer.com/customer/en/portal/articles/1413089-javascript-api-reference#advertising
You will find this callback that will help you:
playerone.on(“adImpression”,function(x){
console.log(x.tag);
console.log(x.creativetype);
console.log(x.adposition);
