Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Help Adding Button
Hi,
I'm trying to add a download button to out player without success. The code for the player on our page is:
<script src="//content.jwplatform.com/players/l9aqB9m4-7l7ZMsAW.js"></script>
<script>
When I tried to add the download button based off the example page it just doesn't show.
<script>
playerInstance.addButton(
//This portion is what designates the graphic used for the button
"https://dl.dropboxusercontent.com/u/53823971/temp_images/icon_download.png",
//This portion determines the text that appears as a tooltip
"Download Video",
//This portion designates the functionality of the button itself
function() {
//With the below code, we're grabbing the file that's currently playing
window.location.href = playerInstance.getPlaylistItem()['file'];
//And finally, here we set the unique ID of the button itself.
"download"
</script>
I just can't figure it out. Any help is appreciated.
3 Community Answers
James Herrieven
User
1 rated :
Try changing the following line:
to be:
jwplayer("botr_l9aqB9m4_7l7ZMsAW_div").addButton(
James Herrieven
Powered by Haiku
http://powered-by-haiku.co.uk/
Tatami for Online Video
http://dev.powered-by-haiku.co.uk/solutions/tatami/
skype: JamesHerrieven
email: james[at]haiku[dot]co[dot]uk
Aaron
User
0 rated :
Thank you James, that worked!
One more question if I may. The button does not function:
function() {
"download"
The player in question is on this page under "Most Recent Audio Sermon)
http://www.livinghopesda.com/
Aaron
User
0 rated :
Okay, I got it to work but I was oping it would automatically download the file. Instead the player changes its appearance and I still can't actually download the mp3 to my computer.
<script>
"http://static.wixstatic.com/media/97b69b_bad03957881648f79c17f33ef58c5ffa.png/v1/fill/w_40,h_40,al_c/97b69b_bad03957881648f79c17f33ef58c5ffa.png",
"Download",
function() {
window.location.href = 'http://www.stephaniequinn.com/Music/Allegro%20from%20Duet%20in%20C%20Major.mp3';
"download"
</script>
