HLS STREAM NOT PLAYING
Hello,
HLS live stream not playing, Error loading player: No playable sources found, but mp4 playing fine,
Regatds
Hello,
Regatds
you asked this once before in the other heading,. Did you test with the stream tester?
HLS streams will not work in the Free version of the player. What version of the player are you using?
Does your HLS stream work in our Stream Tester at http://demo.jwplayer.com/stream-tester/ ?
