Which embed format is better for SEO
Hello, I just had a question whether Javascript or Iframe embed code has an edge or higher impact on the other for SEO. Or if they both have equal impact? Thank you.
Depends on where your iframe is loading from, but Javascript would load from the same domain as the viewer and the iframe would potentially make it appear as though the content was loading from a different domain.
