Custom text for "Live broadcast" and other scenarios
Hello,
we need the same feature as explained on this former question:
https://support.jwplayer.com/customer/portal/questions/6244007-live-broadcast-text
We would need to be able to customize the text "Live broadcast"...
Plus the other texts that are injected inside the 'jw-text-alt' node such as "Loading ad".
Right now, the only way we can achievr this is by changing it inside the source code of jwplayer itself.
We should be able to change it via an additional parameter in the player configuration, leaving the source code untouched.
Can you help ?
Thank you very much.
